Supercharge block vs N/A block - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2008, 07:36 PM   #1 (permalink)
sgtnavytiger's Avatar
View sgtnavytiger's Photo Gallery
Hello all,
I know that the block of a supercharged 4agze motor is structurally stronger than the N/A 4age motor, so does this mean that the crank and connecting rods are also stronger? Thanks for any help!
sgtnavytiger is offline   Reply With Quote
Old 02-16-2008, 06:43 AM   #2 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
Yes
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 02-16-2008, 10:25 AM   #3 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
Yes and no. The 4A-GZE has a stronger bottom end than the earlier 4A-GE's, however the later units (88-on) all have the same block, crank, and rods.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 02-16-2008, 10:49 AM   #4 (permalink)
Thanks a lot guys!
Old 03-09-2008, 11:32 PM   #5 (permalink)
Gameroom cash: $134355
all 88 on's have connections internally for oil squirters, but 88-89 only had them in the 4agze's
the 4agze also has lower compression pistons that are factory forged and ceramic coated
the cranks in the earlier (85/86 some 87) are a bit smaller with smaller rod journals
Old 05-19-2008, 03:35 PM   #6 (permalink)
aux
aux's Avatar
View aux's Photo Gallery
...actually, the 4age went from 5 ribs to 7 ribs in 87-88, reinforcing the strength of the block. however, nothing of major importanced changed until the smallport. im not sure if the smallport had forged internals like the ze..
aux is offline   Reply With Quote
Old 05-19-2008, 04:43 PM   #7 (permalink)
Jeff Lange's Avatar
The crank, rods, and pistons did change in 88 as well to the larger ones. The small internals were never used after 87.
Jeff
Old 05-20-2008, 04:24 PM   #8 (permalink)
Jeff
but you forgot to mention that large were used in some 87's
i'm also not positive that the rods are the same.... although they have the same size journal and pin sizes, I believe the gze's are actually beefier..... the 20V's are def different than the larger 16V n/a and I think the 20V and gze are almost identical
