I have a td06 in my mr2. I have never had any problems. It is a great turbo for the low 300 range, it spools pretty quick. As for the heat shield, MR2 bad is right, you should not have any problems, Just make sure there isn't anything too close to any of the hot side of the turbo. The higher temperatures will melt anything that is resting on the turbo or the lines. If you have heard of any fires under the engine compartment, I would be willing to bet this was the cause of it. The only reason i said ealier to only run it in a pinch is that i do not know the condition of the engine bay. I do not want to be the one to tell you it will be fine and then something happens and you melt something.
