Originally Posted by moogleX
some good info, will the CTD06 bolt right on and use stock lines? or will we need a "kit" to get everything to work. This would be a better option than the spud, since it with a kit is 2k.
The links Piddy posted explain everything. And there are pictures too.
It's a direct bolt on. Both stock oil and water lines are used for the set up. The turbo comes with the actuator and utilizes an internal wastegate exactly like the CT26 and CT20b. There is also a test program they will initiate when they are ready. If you participate, you will get a discount , but you must also get a dyno done and send the results to them.
