Front Right Vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2008, 07:15 PM   #1 (permalink)
Sprtan732's Avatar
View Sprtan732's Photo Gallery
Gen1 Front Right Vibration
Dad and a friend tell me it could be wheel balancing, and another friend says it could be suspension.
Basically between 50-60 mph there is a really bad and loud vibration on the front right wheel, that also makes the steering shake. Anything under or over that speed is ok. Also theres a bit more noise on bumps, but nothing too violent. Any suggestions/ideas?
Sprtan732 is offline   Reply With Quote
Old 04-07-2008, 07:22 PM   #2 (permalink)
jlspec's Avatar
View jlspec's Photo Gallery
I'm going with what your dad said. I had the same issue with one my rear tires, and after a balance it was all good.
1990 Celica Turbo All-Trac
jlspec is offline   Reply With Quote
Old 04-07-2008, 07:27 PM   #3 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
oem wheels?
ToyotaTechGeek is offline   Reply With Quote
Old 04-07-2008, 07:55 PM   #4 (permalink)
Sprtan732's Avatar
No theyre not OEM. I did not put them on the car, they were already on when I bought it. They LOOK alright.
Old 04-07-2008, 10:55 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Given the speed at which it occurs, I would say balancing too. Get it done. It doesn't cost that much and it will illiminate that possibility.
The Jedi Speeder at CarDomain
Old 04-08-2008, 06:28 PM   #6 (permalink)
Sprtan732's Avatar
but would balancing make bumps louder?
Old 04-08-2008, 09:04 PM   #7 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
I would check balancing first. Cheapest and easiest. Next I'd check tie rod ends. Grab a hold of them and give em a shake. If they are loose, that could be your problem. Then I'd check ball joints.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 04-08-2008, 10:00 PM   #8 (permalink)
Sprtan732's Avatar
Gen1
yea i'm not very mechanically inclined, especially when it comes to suspension, i know next to nothing. I'm taking it to the mechanic tomorrow for inspection and a general once-over. He'll probably find the problem.
Old 04-08-2008, 11:12 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
dead/broken strut is also another possibilty.
Old 04-09-2008, 05:20 AM   #10 (permalink)
might want to verify if the wheels are hub centric or not.
