what is the difference between 93USDM Turbo and 94 JDM Turbo engines? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2008, 01:18 PM   #1 (permalink)
View Przemik2008's Photo Gallery
hi what is the difference between 93USDM?
and 94 JDM turbo engine?
I want to know everything. All I know is the wiring different and turboct26 and ct20 B and 93 has 200 hrspwr and JDM has 245hrspwr. Any information will be helpful. Thank You
Przemik2008 is offline   Reply With Quote
Old 04-15-2008, 03:37 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
I'm seroiusly going to commit suicide if you make one more thread about the difference between '93US and '94JDM engines.....
Originally Posted by DavidV
- MAP sensor instead of AFM
- Bosch D-Jetronic (Gen III) vs. L-Jetronic (relatively primitive) engine management
- CT20b turbo replaces CT26
- Boost raised from 10psi to 13psi
- Fuel cut raised from 12 psi to 18 psi
- Different ECU
- 4 wire O2 sensor
- Shim under bucket valve shims
- slightly more aggressive cams
- Revised internals (pistons, con-rods etc.)
- Revised cylinder head cooling passages/water jackets
- Revised intake manifold (8 'independent long ports' reduced to 4)
- intake manifold inlet air temperature sensor added. i.e. after turbo and intercooler.
- Revised gearbox with close ratio gearing
- lower compression ratio
- stainless steel head gasket
- factory 540cc injectors replace 430cc injectors
- revised fuel rail with bigger bore and relocated pressure regulator
- TVIS eliminated
- EGR eliminated
- LSD in 80% of them
- throttle body increased from 55mm to 60mm
- inlet valve lift increased from 8.2 to 8.7
- Less restrictive exhaust elbow
- Aluminum oil pan
- more rigid alloy sump and additional oil baffles
- Factory Catch can
- Better Oil Cooler and relocated oil filter (bottom)
- 4 Channel ABS coupled with Traction Control available
- No. 1 compression ring described as 'stainless steel' instead of just 'steel'. Oil ring is described as 'stainless steel' instead of 'a combination of steel and stainless steel'.
Old 04-15-2008, 04:02 PM   #3 (permalink)
YOU are MR@ EINSTAIN !!! VERRRY IMPRESSIVE ! THANK YOU!
Old 04-15-2008, 11:43 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
if that don't answer your questions ,nothing will !
The Jedi Speeder at CarDomain
Old 04-16-2008, 12:04 AM   #5 (permalink)
hahha
