head swap on a 5sfe??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2008, 08:17 PM   #1 (permalink)
View tdj_1992's Photo Gallery
i was wondering if you could put a 3sge or a 3sgte head on a 5sfe? and if so what do you think would be the out come.
thanks, tommy
tdj_1992 is offline   Reply With Quote
Old 04-15-2008, 10:57 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
You can use the 3sgte head with cams and built a potent engine that way. But the 5sfe block does not have the ports to run water to the 3sgte head. I believe you can use the 3sgte head gasket as a template and drill the holes to access the water from the block. Do some research for details. But it's already been done. I've been thinking of getting my hands on a N/A and going this route.
I'm not familiar with the 3sge head.
The Jedi Speeder at CarDomain
Old 04-16-2008, 02:41 AM   #3 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
I belive teh 3SGE head is the same as the 3SGTE head, its just the internals are different.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 04-16-2008, 10:27 AM   #4 (permalink)
ok ill look into that. but isnt the head on a 5fse a double over head cam with a gear drive going to the intake gear? so if im right what timeing bealt would i use? and would there be more of a chance of over heating??
Old 04-17-2008, 12:19 AM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
No, They're both belt driven twin cams. You would also have to swap out the crankshaft gear and cam gears from the 3sgte. You would use the 3sgte timing belt
