I decided I'd leak a little bit of info about my car to the public. Basically what happened is I parted out my old MR2 to built a new one.... and got a bit carried away.
We started here:
Currently it looks about like this:
Everything is pretty much done. We plan on being on the dyno by next week.... I'd say probably about a month before all of the little quirks are worked out with registration and whatnot.
Here is the semi-official mod list:
Body:
- '91 Toyota MR2 Hardtop
- Custom Ferrari Red
- Black engine bay, trunk, frunk and visible underbody.
- '94 Front Lip
- '94 Rear Wing
- '94 Tail Lights (USDM)
- '98 Clear Corners (JDM)
- '98 Front Side Markers (JDM)
- Color matched mirrors and side moldings
- Custom vented trunk lid
- Shaved antenna
- GRT Flat Bottom Underbody Panels
Interior:
- Sparco Torino Seats with Wedge Engineering Brackets
- Harness Bar (
TBD)
- Harnesses (
TBD)
- Defi DIN-Gauge Unit (Oil Pressure, Oil Temp, Water Temp)
- Omori 45mm Boost Gauge (stock mounted in cluster)
- Innovative Wideband Gauge
- Apex-I PowerFC Commander
- JDM 180kph Gauge Cluster
- OEM Nardi Steering Wheel
- TRD Short Shift Kit
- '98 Shift Knob (or as Allen calls it…. an overpriced regular shiftknob)
- Fully insulated with dynamat
Suspension/Wheels/Tires/Brakes:
- Cusco Zero-2R Coilovers with custom Swift Springs
- Tanabe Front and Rear Sway Bars
- Tanabe Front Under Brace
- Cusco Front and Rear Strut Tower Bars
- Enkei Racing S (17x8+27 / 17x7.5+33)
- Toyo Proxies T1R - 255/40/17 (Rear)
- Falken Azenis 615 - 215/40/17 (Front)
- Rotora BBK (Front) (
TBD)
- WolfKatz Engineering BBK (Rear) (
TBD)
Engine and whatnot:
- Custom Built Hybrid 3rd Gen Block/Head (Over $10k worth of internals alone)
- Walbro 255lph Fuel Pump
- Sard Racing Fuel Pressure Regulator
- Sard Racing Fuel Rail
- Sard Racing 850cc Injectors
- Jun Intake Manifold
- HKS 3rd Gen Top Mount Exhaust Manifold
- HKS GT Series Ball Bearing Turbo
- HKS External Wastegate
- Sard Racing Blow Off Valve
- Custom 3" Downpipe
- Berk Technologies V2 - 3" Exhaust
- HKS 264 Cams
- HKS Adjustable Cam Gears
- 24x12x4 Custom Trunk Mounted Intercooler
- Custom Intercooler Piping
- Custom Intake
- Custom Side Mounted Oil Cooler
- AEM Water/Meth Injection Kit
- Apex-I PowerFC Engine Management System
- '97 E153 Tranny
- Chico Race Works Heavy Duty Axles
- OS Giken Twin Plate Clutch
That's just about all I can think of off the top of my head…. That doesn't include the random little crap we've bought from Toyota. For example…. 90% of my interior is brand new in Toyota bags…. waiting to be put in. Woot. Keep me away from a calculator and I should be jusssst fine. This thing needs to be done already.
