5 speed conversion aw11 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2008, 05:23 PM   #1 (permalink)
View mistajwong508's Photo Gallery
USA 5 speed conversion aw11
I have a 89 MR2 that im restoring ive had it forever and i alrady stripped the engine bay i just need to know what spesifications i need for the 5 speed conversion.....do i need a manual ECC....when i did my lexus i swaped a supra motor in it and i only had to change the ecu if i was to go from manual from auto and its a toyota made car and engine any help would be great thanks
mistajwong508 is offline   Reply With Quote
Old 04-23-2008, 07:44 PM   #2 (permalink)
Gameroom cash: $134355
you will NEED:
Transmission
Shifter assembly
Both cables & the clips that hold them in
Bracket on trans side for the shifter cables
Clutch fork & t/o bearing
MT starter
Flywheel, clutch, PP
Slave cylinder
Master cylinder
hydraulic lines that run between the 2 (which yes, go from the front trunk to the engine bay)
Clutch pedal & brake pedal
the wiring and ecu do not NEED to be changed... you will have a CEL on all the time, however.... the engine will run the same
Old 04-23-2008, 08:42 PM   #3 (permalink)
there is 2 clutch calbes?...i did a 5speed convershion to an integra like hondas i know them like nothin okay umm do you have like pics of this stuff and like where i mounth everything like not the brakets but like you know i need like detailed steps and i cant use the stock auto brake peattle? and whats pp?
Old 04-24-2008, 02:49 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
pp= pressure plate
The Jedi Speeder at CarDomain
Old 04-24-2008, 02:45 PM   #5 (permalink)
ya i relized that after i was like pp? ohhh okay yea i wasnt thinking
