Originally Posted by toyotaspeed90
yes.... the egr tube might be in a different location, though
I will assume the question applies to normally aspirated (N/A) engines ... yes it will fit ... if the egr tube is different, it will be an obvious difference ... if the engine the manifold comes from is available, that tube can be swapped over from the donor ... regards ... Ken
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways - body thoroughly used up, totally worn out and screaming, "WOO HOO, What a Ride!"
