T/o bearing? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2008, 05:56 PM   #1 (permalink)
View mistajwong508's Photo Gallery
USA T/o bearing?
whats a t/o Bearing
mistajwong508 is offline   Reply With Quote
Old 05-03-2008, 08:30 PM   #2 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
A throw out bearing is a bearing located in the transmission that sits on top of the Clutch Pressure plate. When you press on your clutch your slave cylinder pushes a fork in that in tern pushes the throwout bearing into the pressure plate tabs. It compresses the tabs releasing the tension off the clutch. All the bearing does is rotate with the clutch/flywheel so that it can release the clutch with no friction.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 05-03-2008, 11:20 PM   #3 (permalink)
USA
sooo im doing a 5 speed conversion if i buy a trany would it be in the end all ready or ill have to buy it with the clutch fly wheel and presure plate ...shouldnt it come with a clutch kit?
Old 05-03-2008, 11:33 PM   #4 (permalink)
View 92MKll's Photo Gallery
if it is a complete clutch kit it should come with the t/o bearing and the grease, like the name just throw out the old one. But yes a complete clutch kit will come with one
92MKll is offline   Reply With Quote
