boost problem...any ideas?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2008, 06:10 PM   #1 (permalink)
View mitchparker's Photo Gallery
Question boost problem...any ideas??
I am running a 92 turbo all stock except the intake...when I accelerate from a stop my car takes off super slow...I have to rev it to around 4000rpm in 1st just to keep up with the car in front of me. When I push the car I noticed the boost gauge (stock) only goes up half way and its only at high revs. Anyone have any idea as what this could be? It seems like it has gotten worse over the last couple of days. Thanks
mitchparker is offline   Reply With Quote
Old 05-05-2008, 08:01 PM   #2 (permalink)
View Apprentice972's Photo Gallery
First off is the car bucking? Or is it knocking?
Apprentice972 is offline   Reply With Quote
Old 05-05-2008, 08:36 PM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
how old are you ignition components??...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 05-05-2008, 09:19 PM   #4 (permalink)
As far as I know, they are the original ignition components. There is no bucking or knocking the car just doesn't accelerate. Basically I have no boost in 1st gear then it kicks in at around 4000rpm in second and then in the high rpm ranges in the other gears. I am going to check all my lines and my exhaust to make sure there isn't a leak anywhere. I've heard of this happening but haven't heard a solution yet. I'll start from there and see where it goes...
Old 05-06-2008, 08:59 PM   #5 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
I'd definately get some fresh ignition components to start. New plugs, wires, cap, and rotor.
If that doesn't solve the problem, you might want to consider hooking up an aftermarket boost gauge and see exactly what you're boosting at. If you can't boost past 7-8psi, it's possible you're in "limp" mode. One or more of your temp sensors may have failed.
But I'd do the ignition components first. Probably about time to replace em anyways.
Good luck!
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
