wont seal right! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2008, 11:05 PM   #1 (permalink)
View jesse0880's Photo Gallery
wont seal right!
im having a problem geting my wastegate to make a good seal with the manifold side of the exhaust flange on my 91t. should i use a sealant plus the gasket, or should the gasket alone be fine... cause its not working out that way.
jesse0880 is offline   Reply With Quote
Old 05-06-2008, 09:03 PM   #2 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
By what you said, I'm assuming you have aftermarket turbo and exhaust manifold with port for external wastegate?
Either way, the gasket should be enough. You sure exhaust manifold isnt warped in any way?
I suppose trying the sealant couldn't hurt, though.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 05-07-2008, 02:23 PM   #3 (permalink)
its a ATS ex. wastegate adaptor kit. the problem section is where the wastegate meets the adaptor flange.
wat kind of sealant can i use?
Old 05-08-2008, 11:23 AM   #4 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
you dont use a sealant...all you need is a gasket. You can get them just about anywhere. They should have came with the kit
TheEngineer is offline   Reply With Quote
