Acceleration Troubles...
I own an 85 MR2 that recently spun a bearing. It now has a rebuilt engine in it that runs fine except for one thing, at around 6,000RPM the engine holds back and will no longer accelerate. If you rev the engine in neutral, or accelerate around quarter throttle, the engine will make it all the way to red line. The old engine didn't have this problem, and we reused parts such as the TVIS, distributer, MAF, and pretty much everything else. All of the obvious spots have been checked: fuel pressure, fuel filter, MAF, throttle position sensor, air filter, spark plugs, timing and the like. Haven't check the pressure regulator or injectors. Figured since the engine was rebuilt they would be alright, but wouldn't rule it out. Any thoughts on this? Since it seems the problem only happens when you're putting a load on the engine, I can't think of any way to re-create the problem when its just sitting in the driveway. Any help would really be appreciated. I've posted the same problem on mr2.com already. Thanks for the help!
