Engine skipping - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2008, 05:09 PM   #1 (permalink)
View snowdeity's Photo Gallery
Engine skipping
I've got a 93 non-turbo, and just made a few changes to it and it's recently been skipping. I bought some pulstar plugs, if you've ever heard of them. High performance, so on, so forth. Anyways. As I was changing the spark plugs out, in one of the wells there was what looked to be a bit of dirty oil coating the well and top of spark plug, inside the cap. But again, this was before I put the new plugs in, and it wasn't skipping before the new plugs. So, I put the plugs in and the idle isn't constant; it's skipping, although the acceleration seems a little smoother. Today I just bought some new spark plug wires and put them in but it didn't solve the problem. Anyone have a clue why it's started to skip? Maybe the oil dropped further down into the well?
snowdeity is offline   Reply With Quote
Old 05-12-2008, 10:34 PM   #2 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
are the plugs gapped properly? Are you sure all 4 are firing?
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 05-12-2008, 11:30 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Have you also checked your cap and rotor?
The Jedi Speeder at CarDomain
Old 05-13-2008, 02:49 PM   #4 (permalink)
I'm almost positive the gap is right. I thought at first the gap was supposed to be the same as stock spark plugs, but evidently since these are "pulse plugs" I was told to make the gap .040" and I'm pretty sure the cap is fine, not sure about the rotor; and also not sure how to check it. Heh.
Old 05-13-2008, 03:08 PM   #5 (permalink)
View aznstylez's Photo Gallery
Those pulstar plugs freaking cost alot for one. What else did you change while changing the plugs.
aznstylez is offline   Reply With Quote
Old 05-14-2008, 04:34 PM   #6 (permalink)
Ehh, changed the oil. Switched from high mileage to full synthetic royal purple oil. That's it. Then changed the plugs. Then changed the plug wires.
Old 05-14-2008, 11:55 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I was looking at the BGB, and it states the gap for plugs in the 5 sfe is 0.43 in (1.1mm)
Sounds like a big gap to me, but thats what it says.
Old 05-15-2008, 01:21 PM   #8 (permalink)
Yeah, that's what I had them gapped at originally, and I emailed a guy about the skipping, he said this:
> That gap in your manual is for a spark plug, this is not a spark
> plug. You must gap this plug at .040. This is a pulse spark and it
> must be gapped to our specifications. This is probably why the car
> is jumping.
And so, I re-gapped them to that. Still jumping though.
