You've probably have a leak somewhere. I'd try to find it. Freon is not cheap and it could end up leaking out in no time! There is a florecent dye you can run thru the system that when exposed to Blacklight, will glow and reveal the leak.
Access to fill A/C system is in the Frunk(front trunk). Use the low pressure side to fill.You can get the specific details from the BGB in the sticky on the 1st page of this forum.
You can get a kit to do this from Wal Mart for alittle less that $30.00 includes freon, hoses with connectors and pressure gauge.
