Drop Or Pull? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2008, 11:54 PM   #1 (permalink)
View 92MKll's Photo Gallery
Drop Or Pull?
I just bought a JDM 92 rear 3sgte clip that will go on to 92 5SFE. The clip is coming in Wed. i have a couple of questions?
1. Any major mods do i need to do ex. motor mounts
2. Is it possible to lift the motor out and drop the new one in from the top?
3. If from the top then how? If from the bottom then whats an easy way to get the car in the air high enough (keep in mind this will be done in my drive way w/ limited tools jack and 4 jack stands) ?
92MKll is offline   Reply With Quote
Old 05-18-2008, 01:05 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
If you have a hoist, go from the top.
I don't feel comfortable safety wise being under a car jacked up high enough to remove the engine from underneath. If you must goes this way(underneath) ,I would remove the head and oil pan to shorten the hieght neccessary for the engine to clear the frame .
The Jedi Speeder at CarDomain
Old 05-19-2008, 01:56 PM   #3 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
dropping the motor from the bottom is much easier, I think. Just use the engine hoist to lift the rear end of the car high enough to lower the motor onto rollers or floor jacks, then you can roll it out from underneath.
good luck!
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
