ECU electronic specialist please help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2008, 06:26 PM   #1 (permalink)
View Przemik2008's Photo Gallery
hi I'm swaping engines 93 turbo into 94+ turbo. Everything works fine exept Power steering ...
I thinkthe problem is in ECU because on older one from 93 ECU when I connect it with JDM 94+ engine and wireing , there is power stering but the engine shut down after a whille.. On JDM ECU 94+ the engine runs smooth andthere is no problem at all exept this PS.
As You see on the diagram (PS) there is no Power steering on 94+ ECU... Can someone explain me why?
And what is ATS ???
What should I do?
Przemik2008 is offline   Reply With Quote
Old 05-20-2008, 04:26 PM   #2 (permalink)
Gameroom cash: $134355
I wonder if since the PS is electronic it requires the ecu to fire some sort of idle up......
I'm not 100% positive, though
Old 05-21-2008, 03:49 PM   #3 (permalink)
yeahh how do i do that? Does mechanic can fix that? do you have som links to study how to fix it?
