Hi guys.
I had put a post in the introduce me forum and someone on there mentioned that they hadn't seen a 3vzfe swap into a mk1 mr2 and suggested I came across here and posted some pics.
I've already got some pics uploaded.
So here goes, the project so far.
The original car.
Currently supporting different alloys and a bit more rust than the pic shows.
And the original engine which I'm sure you all know is a cracking little engine.
Preparing for removal of old engine.
Engine and original mounts removed
New mounts cut and welded into location
Battery relocated to front.
No need to explain this one, altho it now has no egr system.
Engine sitting under car ready for hoisting upwards and to its new home.
Upwards she goes.
Engine looking out from the bay at us
Looks at home here.
You can see where we chopped the rear wall and bent it back to fit the engine.
Relacation of shaft bearing to fit the camry carrier.
Thats the pics for now.
One final bit.....
The first passenger run.
http://www.youtube.com/watch?v=Dj8CvZonEiw
at that time it was running a crappy temporary exhaust.
so the list so far...
MR2 mk1 AW11
3vzfe engine.
MR2 turbo gearbox clutch and modified Flywheel.
Modified mr2 turbo driveshafts
now sporting a double stainless 3" backbox so sounds a little different.
Corbareu bucket seats and 3 point harnesses.
17" Dezent alloy wheels.
To go on...
Celica ST205 front calipers and modified disks.
undecided suspension
Lambo Door conversion (1 fitted but not perfect so some work required)
Carbon fibre bits hopefully will be made.
New head gaskets seen as the current ones are suspect.
Plus loads more to come once that lot is done
Its a lot of fun to drive and I can't wait to get it back.
and finally, the temporary ride for when its too wet to take the bike out
This one is my stripped out trackcar.
Stainless exhaust
induction kit and completly stripped interior, infact the dash clocks are held in with zip ties and the switches with Gaffa tape.
Anyway I'm off away on the bike for the weekend now so catch you all sometime Monday
