You actually would have been better off leaving the cabin harness intact. If you got a good, uncut engine harness, there is minimal splicing needed to make it work with your current body harness.
Only 1 of the harnesses in front of the firewall needs modification to work, aside from a few other odd wires here and there.
Let me see if I can find the diagrams of the NA body harness and give you some help.
In the meantime, if your NA body harness was working well, I'd consider putting it back in. The only thing you'll have to really worry about is the mechanical speedo, which is a quick fix.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
