Thanks alot toyotaspeed90, that was the fuel problem dang wires
. well on 2 the next one; now i have an ignition problem. now the car fires then dies and i have 2 codes. A no RPM signal, and Switch signal (codes 6 and 11). Im thinkin that the SW signal is from the AC when i removed th AC compressor during the engine rebuild. Now on to the real problem im losing spark after the first few seconds after it kicks. If i let the car sit for about 30 min or so it will start enough for me to get it started then keep my foot on the peddle to keep it running. But after it dies i test for spark and there is none.
. Whats weird is that if I took the #1 plug out and arced it on the valve cover the engine tried to run. So is it a Ground issue? I just painted the head when i had it off. If the plugs aren't getting ground why would it run 30 min. later?
Thanks for all the help so far,
please keep it up.
PS.. sorry it took so long to get back, i went on vaction. Im also asking this on a new thread this time.
