Easy way to check clutch is to put it in 5th when stopped and let the clutch out slowly and try to keep the RPMs at about 1000, it should bog the motor rather than stay the same RPM. The more the bog and the quicker it bogs down the better the clutch. If it is easy to keep at 1k RPM with the clutch mostly out then it's toast.
As for the lag at 4k RPM, it could be from insufficient grade gas, like not running Premium Unleaded or something higher.
EDIT: Or it could be the plugs :P
Reason: Question Answered
