I have used iridium SP's on all my MR2 including the 89 SC MKI i own now. I have never had any issues with them whatsoever. I have been using them on my current 2 for going on 3 years now with no issues.
From all the stuff i've read though it seem that turbo's may be prone to ceramic breakage more than N/A because of Detonation. MR2BAD is correct when he mentions the reason to use Iridium plugs.
Here is a posting from Denso's FAQ site. at
http://www.densoiridium.com/faq.php
"Q. What kind of performance will I get from this plug?
A. Generally, you do not purchase spark plugs for performance enhancement. While DENSO Iridium Power spark plugs have contributed to numerous accomplishments through dyno-testing and actual use, their true benefit lies in their efficiency, durability, and improved firing power. Serious tuners modify their vehicles by increasing boost through turbo-chargers, super-chargers, and Nitrous. They are also known to add high-energy ignition systems, tinker with timing, adjust fuel mixture ratios, and increase horsepower through other means. Putting these kinds of demands on their engine increases the need for an efficient, durable spark plug that can handle these kind of harsh environments. That’s where DENSO Iridium Power can make a major difference.
I've always kept in mind that the insulator is what takes the brunt of the high temperature abuse, so logically speaking since the plugs last longer without needing to be replaced the insulator becomes brittle and lends to breakages.
The big benefit in my humble opinion of using iridium plugs aside from them lasting longer is the fact that ridium spark plugs require on average 5,000 fewer volts to fire than conventional spark plugs.
Less power is required to fire which makes the burn a more efficient burn.
As far as what to use? I can only share my experience.
"They make fun of us cause we are different... We make fun of them because they are the same"
---- The Freak.. (rip) WYYX 97X --circa 2000----
