88 mr2 auto switch to 5 spd - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2008, 06:29 PM   #1 (permalink)
View clever Mr. 2's Photo Gallery
im about to switch my 2 to a 5spd and im just looking for some advice on what to watch for as far as complications im getting ready to go buy the tranny,shift cables,shifter assembly,brake and clutch pedal assemblies,and master cylinder,and slave cylinder is there anything else im going to need?
clever Mr. 2 is offline   Reply With Quote
Old 06-30-2008, 09:05 PM   #2 (permalink)
View Dreams0099's Photo Gallery
Clutch sensor of some type, would hate to crank the thing while it's in gear and it start moving around on ya. That might come with the clutch pedal though. Does the instrument cluster have a position indicator on the automatics? If so you might want to change it out too. Is the clutch reservoir part of the master cylinder? Just some things that come to my mind.
Hope it helps!
Dreams0099 is offline   Reply With Quote
Old 06-30-2008, 09:12 PM   #3 (permalink)
i know it doesnt have a position indicator and im not to sure about the resevoir ill have to look into that but theres not many around where i live
Old 06-30-2008, 09:31 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
The clutch master (master cylinder for clutch) has it's own reservoir. I'm not sure if the 1st gens have a clutch safety switch. The other gens do, so maybe it does too.
The Jedi Speeder at CarDomain
Old 07-01-2008, 07:47 AM   #5 (permalink)
It does , you really don't need one, but it keeps you from accidently cranking it while it's in gear. The new Tacomas have a button on the dash for the 5-speeds that overrides the saftey switch. It's fun messing with them.
Old 07-01-2008, 08:43 AM   #6 (permalink)
so i can by pass the clutch safety?
Old 07-13-2008, 06:24 PM   #7 (permalink)
carrebuilder's Avatar
View carrebuilder's Photo Gallery
Techinically yes but not recommended. I have never done the swap personlly but i did some homework cause i want to do the swap for mine. Some things to watch for; clutch kit, mastercylinder and slave cylinder, trans axles, new seals for a used trnsmission, cables, shifter, shifter brackets and linkages, maybe transmission mounts(dont remember), and the transmission itself. PLEASE let me know if i forgot somthing or correct me if im wrong.
Good luck with your swap.
P.S. If i remember right you may get a check engine light since the ECU thinks that the PCM still exist.
87 MR2 check these sleepy eyes
95 Jeep ZJ
http://www.cardomain.com/id/CarRebuilder
carrebuilder is offline   Reply With Quote
Old 07-14-2008, 05:52 PM   #8 (permalink)
8URBOXR's Avatar
View 8URBOXR's Photo Gallery
Most other countries cars dont even have clutch saftey switch. A friend of mine has a Skyline R32 he's from englandand he told me when he used to live there not many cars had clutch saftey switches as there not manditory in many countries. His skyline will start up with him standing outside the car just cranking the key. Just figured some people would find that interesting.
-Walter
8URBOXR is offline   Reply With Quote
Old 07-15-2008, 01:54 PM   #9 (permalink)
View SR-1ION's Photo Gallery
I had an RX7 that would crank w/o pressing in the clutch. but no other manual car ever did
SR-1ION is offline   Reply With Quote
