5/mo mr2-t owner - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2008, 01:11 AM   #1 (permalink)
MY FUTURE LOOK
MR22007's Avatar
View MR22007's Photo Gallery
2nd Generation 5/mo mr2-t owner
IM LOOKING TO BUY SOME GAUGES FOR MY CAR.
WHAT ARE THE MOST INPORTANT GAUGES TO HAVE?
I KNOW BOOST G IS #1
WHATS #2 #3 ECT.?
QUESTTION #2
ENGINE CODE # 34
EXCESSIVE TURBOCHARGEING PRESSURE ???
MR22007 is offline   Reply With Quote
Old 07-07-2008, 12:07 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
1st of all, Welcome to Toyota Nation.
Boost gauge, oil pressure and ammeter are the most impotant in my opinion. Are you using a boost controller of some type?
Excessive boosting could be wastegate not opening properly, exhaust leak or boost controller not set properly.
Also, please use lower case when posting.
The Jedi Speeder at CarDomain
Old 07-07-2008, 01:44 PM   #3 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Most important: Boost.
After that: Wideband, oil pressure, EGT, oil temp.
That engine code is probably due to hitting fuel cut. Try clearing the codes and testing again. To clear the codes, reset the ECU.
Ghostyman is offline   Reply With Quote
Old 07-07-2008, 01:58 PM   #4 (permalink)
8URBOXR's Avatar
View 8URBOXR's Photo Gallery
Unless your running a boost controller or increasing your boost in anyway I would say oil pressure is most important. True overboosting is important to watch but if your car is stock I would say oil pressure is most important. My list would go like this:
1. Boost or oil pressure (depending if your car is stock or not)
2. The other #1
3. Oil Temp
4. EGT
5. Water Temp
6. Wideband O2
But it also depends on how you use your car I do a lot of autocrosses and starting to do Trackdays so the temp gauges are more important to me. For an everyday street MR2 I would say get the basics Boost, Oil press, and EGT. What mods do you have perhaps that would be more helpful.
8URBOXR is offline   Reply With Quote
Old 07-07-2008, 07:29 PM   #5 (permalink)
MY FUTURE LOOK
MR22007's Avatar
what is wideband? and what does it do?
really same for all
egt, oil p and oil temp
thanks for your help
Old 07-07-2008, 07:30 PM   #6 (permalink)
MY FUTURE LOOK
MR22007's Avatar
o
and one more thing what is ammeter? and whats it for?
Old 07-07-2008, 07:33 PM   #7 (permalink)
MY FUTURE LOOK
MR22007's Avatar
Q: you ask me
Are you using a boost controller of some type? yes it has a black turning nob by my rad cap
Old 07-10-2008, 11:23 PM   #8 (permalink)
View Dreams0099's Photo Gallery
Originally Posted by MR22007 View Post
Q: you ask me
By "rad cap" do you mean Radiator cap? I really hope not unless it's a full manual one, and in that case you REALLY need a boost gauge to see what you are boosting at. You could be somewhere near 20psi and ruining the motor without knowing it.
Dreams0099 is offline   Reply With Quote
Old 07-10-2008, 11:34 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
There is no radiator cap on the radiators of the 2nd gens. Do you mean the filler cap in the engine bay on the drivers side?
Old 07-10-2008, 11:40 PM   #10 (permalink)
MY FUTURE LOOK
MR22007's Avatar
yes
<rad cap> i just try to make it simple.... sorry
Old 07-10-2008, 11:41 PM   #11 (permalink)
Just because it's not ON the radiator doesn't mean that it's not a radiator cap.
And an ammeter is like the stock Volt meter (battery gauge, don't think the turbo one's have one) but it measures amps rather than volts. On a stock street car about all it does is tell you if your battery is dead or not.
Old 07-10-2008, 11:43 PM   #12 (permalink)
Wide band is basically an Air/Fuel ratio gauge. It tells whether or not it is running lean (not enough fuel) or rich (too much fuel). Both are bad but it is better to run slightly rich rather than lean.
