Bolt Torque Specs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2008, 07:39 PM   #1 (permalink)
Sprtan732's Avatar
View Sprtan732's Photo Gallery
Bolt Torque Specs
I had to replace my "lower arm", "strut bar", and the bracket that attaches the front of the "strut bar" to the body of the car. All are on the front left side (see below)
I need to know what the torque specs are for the bolts circled below:
Thanks lots
Sprtan732 is offline   Reply With Quote
Old 07-16-2008, 11:45 AM   #2 (permalink)
View Dreams0099's Photo Gallery
Most bolts are ok at a German tightness, as in Goodntight.
Dreams0099 is offline   Reply With Quote
Old 07-16-2008, 12:08 PM   #3 (permalink)
Sprtan732's Avatar
yea thats what i usually go by but i figured since these are put under lots of stress id want to get it right
Old 07-16-2008, 06:58 PM   #4 (permalink)
All right, here's the best I could do.
The large bolt in the back part of the control arm (the thing circled with no part numbers) is supposed to be 94 ft lbs.
The ball joint (the thing you marked with an arrow is 58 ft lbs.
90179-12025 is supposed to be 83 ft lbs.
I can't find a spec on the 90170-16183.
Here's some links that will help.
Toyota Big Green Book - http://mr2manual.nbcpgh.org/
Parts search engine for Toyota, helps to find what some parts are called and gives prices, not sure how accurate the prices are but I'm sure the names vs part numbers are correct - http://www.trademotion.com/partlocat...?siteid=214001
Hope it helps!
-Jake
