engine swap problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2003, 09:46 PM   #1 (permalink)
View mk1ldragon's Photo Gallery
engine swap problem
I'm changing my 4agze us dm to a map sensored jspec. I"m using my distributor and ignition. My friend who is putting it in says the us dm engine has oil lines under that the jspec one doesn't have. What do I do?
the jspec tranny is different then mine. the shifter cable is on the other side. my jspec is the one with the front mount intercooler. I know I gotta use the usdm piping for the intercooler....
any help please...
mk1ldragon is offline   Reply With Quote
Old 11-29-2003, 03:55 PM   #2 (permalink)
Ontario's King of AW11
View yellow86MR2's Photo Gallery
you will not be able to use the oil cooler lines from your factory CND motor on the Jspec, unless u swap over the oil pan and all the nesecary parts. If you need a MR2 sc tranny, i have one here in Toronto. To make the Levin tranny work involves a bit of machining work to relocate the brackets for the cables because they are on the other side.
Martin
yellow86MR2 is offline   Reply With Quote
