Well heres the story. I have a 87 MR2 that I just rebuilt the engine. The car ran great for 2 weeks (sort of i washed the engine bay and shorted the TPS senser and the coil, both are new). But suddunly i was driving to work one day and the car just died. I was running a little late and i droped it into low (yes i drive an auto wanting a stick) got it 4500 RPM and it just died like a electrical failure so i checked spark and i have spark. When i took the plugs out and their wet with fuel
( I also cracked the line going to the cold start injector and i got pressure). Well if thats 2 out three main things i need. The last I checked was compression, sure enough I HAVE COMPRESSION (125 PSI).
Now i pulled the valve covers off and the oil looks a little chocolatey not very just a little
(maybe from when i washed the engine bay). NOT GOOD! Any ideas if anything let go. i had the head put together, i did everything else. The car doesnt even try to fire but it rotates.
Any help would be appreciatted! Thanks
Scott
