Originally Posted by MayBF8
A friend sprayed ethanal to check my "spark" & I DO have spark.....but the engine will NOT turn over.
Cranking over and turning over are the same thing.
To clarify here... when you say "will NOT turn over" you mean that the starter cranks the engine but doesn't start running. Otherwise, the distributor wouldn't turn and you wouldn't get spark. Assuming that it's turning over strongly, then the starter is still good (plus you said that popping the clutch didn't start it).
Did you test the fuel delivery? As noted by Dreams0099 above, it's easy to do by just unbolting the fuel line and cranking the engine. If you have a fuel problem, it is likely the pump.
My guess right now would be a slipped timing belt from when the engine was installed. That would explain why it it getting fuel, spark and air but not starting. If you have access to a timing light, it is relatively easy to check the timing. You should be able to borrow a timing light from a parts store or buy a cheap one from Harbor Freight. If this is the case, you should also be able to get it repaired for free by the shop that installed the engine.
We know the timing belt isn't broken because the distributor turns and it is driven by the camshaft which is driven by the timing belt.
Note 2: I like to test spark by sticking my finger in the end of the spark plug wire and making sure I get shocked when the engine turns over. I think I'd be in legal trouble if I recommended this method, so don't do it.
Is this a turbo or a naturally aspirated car? EDIT: I saw in the other thread it is NA.
Feel free to ask questions if anything is unclear.
