finally did my swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2008, 05:27 PM   #1 (permalink)
View clem's Photo Gallery
finally did my swap
hey guys i finally did my swap just have a few questions,i replace the stock turbo with a 61mm precision turbo the car really pulls hard at 10psi i wanted to know how much boost could i run with the stock fuel system and run safely i wanna maximize the stock fuel system before i upgrade the injectors and fuel pump i wanted to turn up to about 18psi how much hp do you think i will make to the wheels?
clem is offline   Reply With Quote
Old 08-02-2008, 09:45 AM   #2 (permalink)
Old 08-02-2008, 02:12 PM   #3 (permalink)
View Dreams0099's Photo Gallery
The piston rings don't like going above 15psi, but the fuel should be fine at 18psi, I was boosting mine to about 21psi before I popped the head off the block. (I had more problems than I knew what to do with)
Should be about 230hp at the wheels, or about 260-270hp at the flywheel (that's if it is tuned right and have the air and exhaust capable of letting the turbo run efficiently at 18psi.)
Dreams0099 is offline   Reply With Quote
