Passenger side window stopped working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2003, 09:06 AM   #1 (permalink)
View 92MR2's Photo Gallery
My passenger side window wont go down. I re ran speaker wire and took door panels off and the window worked than. But I took the drivers side door panel off to try and fit new speaker (didnt fit, 6 1/2 infinity kappa's) and I tried to put the window down and didnt work. Drivers side window goes down too so not the controls on drivers side and the controls on passenger side doesnt do the trick either, It might be the motor if so where can I get one. If ne one has ne ideas would be a great help, thanx.
92MR2 is offline   Reply With Quote
Old 12-04-2003, 02:22 PM   #2 (permalink)
View WillEV's Photo Gallery
Make sure you didn't press the power window override button on the drivers door.
Join my army on King of Chaos
http://www.kingsofchaos.com/recruit.php?uniqid=7p7q4282
WillEV is offline   Reply With Quote
Old 12-04-2003, 02:36 PM   #3 (permalink)
Gameroom cash: $253010
iTrader Score: 6 reviews
View BDSL's Photo Gallery
Check the fuse first!!
The fuse is located in the fuse box right beside the driver's left foot.
It can be loose connectors or damaged wires. If its the regulator or motor, it can be expensive.
Good luck
BDSL is offline   Reply With Quote
