Wierd Trans Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2008, 10:14 PM   #1 (permalink)
carrebuilder's Avatar
View carrebuilder's Photo Gallery
Wierd Trans Light
Ok now that i finally got my car to stay cool it on with the next. Ive gott an 87 NA auto (yea and I hate every second). The overdrive light blinks and its wayyy to constistent to be a loss wire, almost like a troble code. problem is it never stops at all. My overdrive works after the trans warms up but not when its cold. Any ideas on what my PCM it tring to tell me?
87 MR2 check these sleepy eyes
95 Jeep ZJ
http://www.cardomain.com/id/CarRebuilder
carrebuilder is offline   Reply With Quote
Old 09-05-2008, 05:20 PM   #2 (permalink)
NOBODY has any ideas??
95 Jeep ZJ
Old 09-05-2008, 05:43 PM   #3 (permalink)
just a nobody
I know the 'OD' was for retrieving code on some models, but I am not sure about yours. Have you disconnect the battery to see if it will reset?
N.E.O.
Old 09-07-2008, 10:11 AM   #4 (permalink)
Yea I tried it. It only stays of for about 2 min. Then comes right back on.
95 Jeep ZJ
Old 09-07-2008, 12:28 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Does your tranny have a filter? Most auto trans do.If it does, it may be clogged. After it warms up, the filter may be clear enough to operate. Hence, it drives OK after a warm up. Just a thought.
The Jedi Speeder at CarDomain
Old 09-08-2008, 10:20 PM   #6 (permalink)
just a nobody
Usually if it is a clogged filter it would actually get worse as more fluid is passing through the filter screen.
You can retrieve codes for the transmission by connecting TT and E1 in the diagnostic connector.
N.E.O.
