http://www.mr2-tech.com/bgb/mechanic...efi_system.htm
This is useful to know if you dont already. If you are familiar with it, the two pins I mentioned are in the same diagnostic block.
Once you jump those two pins, try and start the car. If it does start, you know the fuel pump relay is not functioning but the fuel pump is. If you still cannot get the car to start, leave the same two pins jumped, turn the key to the ON position and check to see if you feel any fuel pressure/flow through the lower fuel filter hose. If you cannot tell, you can check the fuel return line from the rail.
If you would like to follow troubleshooting by the book, the main page for the online service manual is
www.mr2-tech.com/bgb.htm
Also, if you are still unsure if you have spark - check the EFI 15A fuse in the engine bay fuse box. This will prevent fuel AND spark if blown.
