Problems with acceleration - need help!
My car just got done being built after about 2 long years. I went to pick it up today from the garage and it STILL isnt totally ready.
The car starts and idles just fine, no problems with that at all in anyway, it runs beautifully. It even revs in neutral just fine no problems, the turbo spools and the bov works great, and does not stick at all. The turbo system is totally stock besides the blow off valve (turbo xs rfl), and i have double checked the hoses. The previous owner of the engine had a boost controller on it, that is not on it now (or hooked up at least).
The problem is that when you take off and accelerate, the car runs like it has no power at all, it drives just fine but does not drive like a turbo car. It accellerates slower than my old 5sfe did.
I have looked into the hose setup and its totally fine, as well as any vacuum leaks. Also im not sure of a turbo leak, it sounds totally fine. The bov blows off after 2k or higher, which im pretty sure is normal.
The car has been sitting there for 2 years and the only thing i can think of is that the gas that is in there is the same gas that was in it when i dropped it off ... 2 years ago. Its 87 octane and smells rotten as hell.
Could this old gas be the cause of my poor acceleration? The garage that it was at took it for a test drive yesterday and they said that under acceleration that sputtered and sometimes died, today when i took it out it ran just fine but had no power at all.
Basically im narrowing this down to the gas... or maybe the blow off (because its the only aftermarket thing about the turbo)... or somehow a turbo leak?
Any help is greatly appreciated!! i miss my mr2 so much and i want it back!
