I found this on Wikipedia:
3S-FE
The Toyota 3S-FE is a 16 valve 2.0L twin camshaft, single cam gear engine built by Toyota from 1986 to 2000. Its common use is in the Toyota Camry 1987-1992 model, the Toyota Celica 1986-1989, Toyota Carina II 1987-1992 and E 1993-1998 models, Toyota Corona T190 as well as Toyota Avensis 1997-2000 models and Toyota RAV4, 1994-2000 and Toyota Picnic/Ipsum 1996-2002. It also powers the 6th generation Toyota Celica SS-I and SS-2(Japanese Domestic Market only).
3S-FE 87-90 86.0 mm 86.0 mm 9.8:1 1998 cc 90 kW@5600 rpm 169 Nm@4400 rpm -SS1 (ST202)
3S-FE 87-94 86.0 mm 86.0 mm 9.8:1 1998 cc 85 kW@5600 rpm 162 Nm@4400 rpm Equipped with catalytic converter
3S-FE 95-98 86.0 mm 86.0 mm 9.8:1 1998 cc 96 kW@6000 rpm 178 Nm@4400 rpm Refined valve timing and ECU settings, introduced with Carina E (T19) model
3S-FE 1998-2000 86.0 mm 86.0 mm 9.8:1 1998 cc 94 kW@6000 rpm 178 Nm@4400 rpm Slightly less power with better torque characteristics. Stricter pollution control. Introduced with the new Avensis (T22) model
Unfortunately, TN no longer allows us to carry on line manuals as of a couple of weeks ago. But maybe 1 of the guys in the Camry section can give you the ignition timing. just a thought..
