93 MR2 swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2008, 12:53 PM   #1 (permalink)
B
View Daugherty's Photo Gallery
93 MR2 swap
Now I know that there has been plenty of MR2 articles about making the 3S-GTE swap from the non turboed 5S, but none of which that i could find had to change from auto to manual as I would. I have read about the camry swap and that sounds like a good option for me if i could run the camry tranny and everything would fit from my current auto setting. The negative would be not having LSD. Does anyone have any help or recomondations for me as i will be doing the swap myself so easiest swap would be best. By the way i have 60,000 on the chasis and motor and the car is still original in perfect shape so i would not want to sell for a manual.
Daugherty is offline   Reply With Quote
Old 10-21-2008, 07:21 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
1st of all welcome to The Forum
The subject of swapping in the E153 Trans for the auto has been covered several times.
You will need: Trans, shifter cables,axles, clutch pedal,clutch switch and spring,brake pedal,brake light switch and spring, clutch master w/reservoir, hydrolic lines, clutch slave, retainers and clips to hold hardware in place, stick shift and boot.
And a note-only '93 and up came with LSD..
The Jedi Speeder at CarDomain
Old 10-21-2008, 09:27 AM   #3 (permalink)
mr2oogleX
View moogleX's Photo Gallery
whats wrong with swapping in the 3s turbo tranny?
Originally Posted by Quandry
...Turbo's have vaccum too, it's just not the fun part of the gauge
moogleX is offline   Reply With Quote
