Originally Posted by scooterman
A stock 5sfe can handle over 15 psi on stock internals. I know this becuase my engine is running fine on this, so is mannys and so is shannons.
5sfes dont fail becuase of boost, they fail becuase the stock ecu can not run a boosted engine correctly. Bad timing, lack of fuel and lack of oil kill 5sfe's not weak internals or too much boost.
just cause you can boost it doesn't make it safe.
the non forged stock internals are not designed to handle the amount of heat created. This will drastically decrease the life of those components whether you've experienced it or not.
but if you can control heat transfer better by upgrading cooling and oil, and not letting it run lean you may be able slow it down and the only thing you have to worry about it is overboosting. But if you know engine CFM and the correct formula you can calculate max safe boost for any engine.
where there is a will there is a way for any engine. under 6 psi is the only safe amount you can run w/ a bolt on kit and no complimenting upgrades is maybe wha i should have said.
