Gasket Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2008, 01:51 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Gasket Question
'91 MR2 Turbo.. rebuilt CT26...running 15psi
I want to make the gaskets that go between the turbo and exhaust manifold and the turbine and the downpipe using the kind of gasket material that comes in sheets.
My question is-will it hold up to the heat? Toyota uses those rediculously priced metal gaskets.
Anyone ever tried using this stuff?
The Jedi Speeder at CarDomain
Old 11-08-2008, 02:33 PM   #2 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
MR2BAD:
I actually tried some of that gasket-on-a-roll with my 5sfte engine.... it held up surprisingly well. I wet the roll and laid it out with books on top to dry perfectly flat... (only good use of those encyclopedias I've had yet) used a hobby knife to cut to shape, and doubled them up between the turbo and manifold....
I didn't have any leaks.....
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 11-08-2008, 03:16 PM   #3 (permalink)
no more V-6...
also when I was looking for gasket material I wondered about using thin sheets of copper... and cutting them to shape. so long as both surfaces are decked, you'd think that a single layer or even two layers of a softer metal between the manifold\turbo or the turbo\downpipe would act as a decent if not proper gasket... wondered about brass too, but figured it was too soft.
back to the 4cyl...
Old 11-08-2008, 03:18 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Ok, Thanks Dave- I think I'm gonna go that route..
Oh and are you back in Tennessee?
Old 11-08-2008, 04:11 PM   #5 (permalink)
no more V-6...
yes sir! back in the Nashville area.... but for how long... who knows! once I get the mr2 back on the road I'll be heading back to miami... it's only 63 degrees right now and I'm dieing!!! I know... I know... suck it up!
I'm having alot of trouble getting this latest 3sfe to run... it's a 91 ecu and harness in my 93 car... but the guy I purchased the harness from said it had a map sensor... I'm hoping that will cure some problems when I get one.
didn't mean to alter the direction of this thread
back to the 4cyl...
Old 11-08-2008, 05:25 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Nah, I asked the question-so I'm the guilty one..Yeah, I think we have about the same temps.. You've just gotten spoiled by that Miami weather!
Good luck with you project!
