Originally Posted by willtotheumm
Definately take turns easy. Like they said, you now have the weight of the engine in the back. much easier to kick the back out with them. Good luck and be safe!
how does weight over the back make it more likely to fish tail?
I always figured that the reason FWD is better at starting and staying straight in the snow is because the weight of the engine was over the drive wheels, so it helps the tires get traction
where as most front engine/rear wheel drive cars (and 2wd trucks) have only the weight of the sheet metal/axle/tires making it more prone to fish tailing, because it has less weight over the drive wheels, and it's essentially trying to "push" against the weighted down front
I figured mid engine cars should act like front engine/FWD cars since the weight of the engine is over the drive tires...is this not true?
