Need MR2 MK1 help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2008, 11:46 AM   #1 (permalink)
View Mr.2fresh's Photo Gallery
Gen1 Need MR2 MK1 help
getting cams and cam gears for Christmas, just have a 4age 16 valve, need to know what i have to do for the ecu? and information could be helpful thanks!!!
Mr.2fresh is offline   Reply With Quote
Old 11-24-2008, 06:11 PM   #2 (permalink)
View yimer999's Photo Gallery
i believe that you wont have to change the ecu at all i think all you have to do is correct the timing.
yimer999 is offline   Reply With Quote
Old 11-24-2008, 08:42 PM   #3 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
i would reset the ecu just for fun. i would also consider doing a valve lash adjustment.
ToyotaTechGeek is offline   Reply With Quote
Old 11-24-2008, 09:28 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
You can use the cams without touching the ECU. But it would be better to have it tuned to get the most out of the new set up.. Just make sure the cams are properly degree'd .
The Jedi Speeder at CarDomain
Old 11-24-2008, 10:22 PM   #5 (permalink)
of course you don't actually have to touch the ecu. just unplug the connectors or undo the battery connections. there really isn't a 'tune' available for the ecu. true there are various piggy backs, but...
the Techtom upgrade doesn't really seem to work at all.
Old 11-24-2008, 10:45 PM   #6 (permalink)
thanks for all the feedback everyone, ill be back with updates on the Mr.2
Old 11-25-2008, 02:15 PM   #7 (permalink)
Gameroom cash: $134355
it depends on the duration of the cams.... anything over 272 you will need something better to control the fuel.....you will HAVE to reshim the head to the new cams... if you don't, you run the risk of spitting a shim and destroying the head.
Old 11-25-2008, 02:20 PM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
hhmm..I didn't know that. Does that also apply to the 3sgte since it uses shimmed buckets?
And would that be neccessary for 264 or 268 cams?
Old 11-25-2008, 06:29 PM   #9 (permalink)
yes. the 3sgte is also a shim under bucket. one should always check valve lash when changing camshafts.
Old 11-26-2008, 02:42 PM   #10 (permalink)
anytime you change cams -- even stock for stock, you need to check the clearances... if you don't, you run serious risk of destroying something..... I'm lazy and that's the only reason my smallport 7age still has smallport cams in it... I have shims, I have early cams.... just don't wanna do all the clearances and screwing with the shims....
Old 11-26-2008, 02:48 PM   #11 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I always thought that that side of the cams would keep the neccessary clearances. Thanks for the enlightenment. I do plan on going either 264 or 268. I would have checked clearances, but this will keep me from possibly being shocked and unprepared to re-shim-....if needed.
Old 11-26-2008, 03:46 PM   #12 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
No, it's not a shim under bucket, it's shim over bucket.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 11-26-2008, 04:52 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I knew what he meant. I've adjusted the valves before via shim change.
Are the shims of the 4age inside the underside of the buckets? Just curious...
Old 11-26-2008, 05:32 PM   #14 (permalink)
Jeff Lange's Avatar
Nope, they are also shim over bucket.
Jeff
Old 11-26-2008, 08:26 PM   #15 (permalink)
Jeff
yep. ya got me. i guess i was busy working 'the grid' on my underbucket project.
