1988 mr2 fuel problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2008, 08:25 AM   #1 (permalink)
View ksbr77's Photo Gallery
Question 1988 mr2 fuel problem
hello how is everyone i have a problem with this car i bought for my daughter hope someone can help wasnt getting fuel so changed fuel pump still no fuel
ksbr77 is offline   Reply With Quote
Old 12-07-2008, 07:59 AM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
wow. punctuation much???
check your ignition switch. you can buy it in two parts. you may only need the rear part. start there. also check you fuel relay in the rear of the car (e.g.; engine compartment).
ToyotaTechGeek is offline   Reply With Quote
Old 12-07-2008, 08:58 AM   #3 (permalink)
thanks toyotatechgeek ill check it
Old 12-07-2008, 11:10 AM   #4 (permalink)
Gameroom cash: $134355
also check to make sure your airflow meter is connected.
Old 12-07-2008, 11:26 AM   #5 (permalink)
just a nobody
The fuel pump only gets power when cranking and running. Where did you check for power to the fuel pump at?
N.E.O.
Old 12-07-2008, 05:08 PM   #6 (permalink)
ok it may have power then didnt check when it was turning over anyway i believe we found the problem the guy i bought it from said he put a new fuel pump in but just didnt put it back together so i put it back together and nothing so took tank out and its not a new fuel pump hooked it straight up to the battery and pump still dont work i ordered a new fuel pipe thanks for all of yahs help hope yah all have a merry christmas
Old 12-08-2008, 07:50 AM   #7 (permalink)
View Husband's Photo Gallery
Could the problem be that there are no periods, commas, question marks or semi-colons on your keyboard? hehe
Merry Christmas! Glad you got it figured out
Husband is offline   Reply With Quote
Old 12-08-2008, 02:27 PM   #8 (permalink)
If you get it all together and it still doesn't run........
I have purchased "non running" cars for dirt cheap and driven them home after reconnecting the AFM.....
Old 12-28-2008, 11:02 PM   #9 (permalink)
View Duy-'s Photo Gallery
i had a fuel pump issue too with my mr2. pain in the ass to fix it with a full tank... and i actually forgot where 2 of the hoses went. does anybody know which of the 2 hoses that go from the fuel evaporator to the tank goes? or can does it not matter where those 2 go.
Duy- is offline   Reply With Quote
Old 12-29-2008, 12:27 AM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
What year and engine?
The Jedi Speeder at CarDomain
Old 12-29-2008, 08:57 AM   #11 (permalink)
its an 86 mr2. the two lines go directly from the tank to the evap, it was pretty obvious where they go because one is a bit longer than the other... but i removed them both from the evap and gas tank.
