over torqued cam caps... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2008, 07:33 PM   #1 (permalink)
View jesse0880's Photo Gallery
I just put the cams in my 3sgte and i noticed the torque wrench wont "click" when set under about 20 ft/lbs, and i think they might be too tight. I have the timing gears on and the cams rotate normally. will they be ok?
jesse0880 is offline   Reply With Quote
Old 12-19-2008, 11:16 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
No, follow cam bracket torque specs-14 ft.lbs .Too tight and you will not get proper oiling around journals.
Make sure you do it in the proper sequence.
If you don't have a torque wrench that goes that low, borrow / rent one from O'Rielly's, Pep Boys, Advance, etc.
The Jedi Speeder at CarDomain
