1991 Toyota MR2 5S-FE Tune-Up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2008, 01:22 AM   #1 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
So,
My first post in the MR2 forums, yay.
So, a buddy of mine has a SW20 with a 5S-FE on it. It's a 5spd T-Top with around 140k miles.
It's been parked in a garage for almost 2 years, but prior to that, it ran fine.
We just started it up today, swapped batteries and added some motor oil. Cranked and ran fine. Idle was a bit high after about 10 minutes, at 1000-1100rpm, and wasn't steady. It sounded like it was misfiring when revved up a bit to 3k rpm or so.
I'm just wondering what kinda maintence or tune-up we should do on it to get it running well.
I was thinking of the following:
Oil Change
-5W-30 good?
Flush Power Steering
-Dex III?
Flush Tranny
-Dex III again?
Flush Transaxle
-Dex III as well?
Flush Brake Fluid
-Dot 3/4?
Flush Coolant
-Do I need Toyota coolant, or just pre-mixed coolant from AutoZone?
To fix bad idle:
Spark plugs
Spark plug wires
Timing belt
-From Toyota OEM Parts
Distributor Cap and Rotor
-Where can I find this?
Seafoam and fuel injector cleaner?
Anything else you'd recommend I do or check?
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 12-29-2008, 01:30 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Thats pretty much covers it. As far as what grades of fluid to use, consult the manual. I have the turbo, so I don't know what the N/A takes.
Most auto parts stores carry seafoam.
The Jedi Speeder at CarDomain
Old 12-29-2008, 02:35 PM   #3 (permalink)
thadius33's Avatar
View thadius33's Photo Gallery
5w30 is good, especially since you have cold weather
Nebraska may be lame, but on the upside there are no emission laws
http://thadius33.deviantart.com/ for pics
thadius33 is offline   Reply With Quote
