1987 mr2 Idle Air control valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2009, 03:10 PM   #1 (permalink)
View markovicsr's Photo Gallery
I have a 1987 toyota mr2 with a rough idle at start up I was told by a friend it is the idle air control valve. I was wondering if a 1989 mr2 IAC would fit on my 1987 and does anybody have any pictures of its location and instructions on how to change it. Any help would be great thank you.
markovicsr is offline   Reply With Quote
Old 01-14-2009, 04:32 PM   #2 (permalink)
Gameroom cash: $134355
what makes you think it's an IAC valve? Is it hard to start (ie take longer than usual)? I would lean towards adjusting your idle or checking your cold start injector/switch first
Old 01-14-2009, 06:45 PM   #3 (permalink)
the car starts fine and then the idle will jump to like 2500rpms and stay like that for a while and as the car gets warmed up the idle starts to fall and becomes erratic (dropping and rising) until the car is fully warmed up and then it will stay at 900rpms.
Old 01-14-2009, 07:33 PM   #4 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
first make sure your coolant is bled properly
ToyotaTechGeek is offline   Reply With Quote
