remove anything you want in terms of vacuum... those vsv's won't throw a code and/or cause the engine to run poorly.... block off all vacuum ports you want blocked, and then adjust the idle based on the idle screw in the TB.
I dont' like the EGR setups in the aw11's so I removed ours (on the only bigport car we have).... there's no performance gain to removing them, however (FYI).
