Raise the boost. You might need to disable fuel cut, depending on the car.
What are your final power goals? What type of engine (gen2, gen3) do you have?
HKS cams are a bit of overkill and pretty pricey. The Adjustable cam gears can give you good results by properly setting them on the stock camshafts. Or you can do 3SGE or gen3 3SGTE cams for cheaper.
Before doing cams, I'd look into methanol injection. That will let you raise the boost a bit more and also provide better intercooling.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
