Oil Nozzle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2009, 12:28 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Oil Nozzle
The socket head bolts that hold the oil nozzles in place were a bitch to get out. The machine shop had to cut one of them out and the other socket heads are kinda stripped, so I am replacing them all.
My question: Do I need to use thread locker on the threads when installing? Or are they OK just torqued down?
The Jedi Speeder at CarDomain
Old 01-21-2009, 04:44 PM   #2 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
I wouldn't use thread locker.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 01-21-2009, 07:31 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
OK, thanks. I was just wonderinh why they were so hard to break loose...
Old 01-24-2009, 09:56 AM   #4 (permalink)
View wags70ss's Photo Gallery
The manual does not call for thread locker. I just made sure the threads were clean & dry & snugged them up good & tight.
wags70ss is offline   Reply With Quote
Old 01-24-2009, 11:49 AM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I only have the CD and it's notorious for leaving out stuff. It doesn't say anything about thread locker either, but they were fricken hard to bust loose for something thats only torqued to in. lbs. Maybe the previous rebuild put some on there. Idunno
Thanks
Old 01-24-2009, 03:45 PM   #6 (permalink)
My engine was a JDM unit with 80K on it - never touched. All my bolts came out fine & did not show any signs of having any locker on them, I just cleaned them & put them back in the same way, with no locker. If you use it, use only BLUE not RED & only use a tiny amount, but you may run into the same problem later if you pull it apart again. The nozzles just sit there. There is no pressure on them & they arent subjected to any vibrations or loads, so they shouldnt work loose if you torque them to specs.
