fwd 3sgte celica - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2009, 06:41 PM   #1 (permalink)
View celicaturbo's Photo Gallery
Canada fwd 3sgte celica
i want to swap a 3sgte into my 1990 celica gt,but im not sure if it can be converted to fwd.will my stock celica tranny bolt up?.im looking for a complete engine with all wiring .i was also told that i would require some sensors.i know this is a mr2 forum,but i was told that i would have better luck finding what i needed from an mr2.can anyone help please?
celicaturbo is offline   Reply With Quote
Old 01-27-2009, 07:41 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I think you'd need parts from the Celica AllTrac Turbo. It comes with a 3sgte
The Jedi Speeder at CarDomain
Old 01-30-2009, 02:52 PM   #3 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Your Celica probably has a 5SFE in it... should be a simple enough swap. People do 5SFE->3SGTE in the gen2s all the time. A couple things I think will come up:
I believe the MR2 transmission linkages bolt up on the "wrong" side of the transmission. You can modify a MR2 transmission housing to work by drilling and tapping a couple holes.
You'll need either the Celica GT-Four intercooler (nice top-mounted A2W setup) or do a custom FMIC setup. The MR2 sidemount intercooler won't fit.
The afore-mentioned Celica All-Trac GT-Four did come with a 3SGTE and 4WD. If you can find a front clip from one of them, snap it up quick. Otherwise, swap in a 3SGTE from a MR2.
If you get the option, but a MR2 rear clip. That will have all the sensors you need.
Are you planning on modifying the engine for higher power levels? If so, there are some things you'll want to consider before putting the engine in.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 02-07-2009, 10:09 PM   #4 (permalink)
thinking of swapping the 5sfe for a v6, either a 1mzfe or a 3vzfe.not sure which one yet but it will be boosted.
Old 02-08-2009, 06:58 AM   #5 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
trans from a ST162 (i'm pretty sure that's the one we used...) works. 3SG-E Celica GT-S. the wiring harness you will want is kind of dependent on which 3SGT-E you will use. in your later post you mentioned V6...can't help you with that...haven't done it yet.
ToyotaTechGeek is offline   Reply With Quote
