firstly, no this is NOT the BEAMS engine.
secondly, anyone who suggests using a different engine, please close the browser. i am set with this engine and will finish this swap...
thirdly, its a 1st Gen 3sge from an 88 Celica GTS... i chose this engine on purpose...
forthly, anyone who suggests using a different engine, please close the browser. i am set with this engine and will finish this swap...
below is the original post concern this swap...
i plan on transplanting a 3s-ge into my mr2. i've learned a lot with that little demon out there. i've no doubt that i could learn a lot more in its current standing. i am hitting a noticable limit where i do need more power.
but, as some people know, i'm not a power hungry fiend, and i take what i learn in stages.
so, 140-150hp seems reasonable, and with the fact that i plan on keeping in NA, i can stab the throttle and not force myself to learn finite foot control.
i've talked to a few people about it.
most everyone has said the same thing - get a turbo. it seems that few are listening. i do not like the feel of the turbo. it lags far too much in lower rpm, and the sudden surge of power could easily spell injury (or worse) for me. this is because of my lack of experience driving a turbo.
i've thought about supercharging my mr2. and for a while, it really seemed like the thing to do. but, something has changed that. i didnt like the feeling of increasing the power so suddenly - again, lack of proper foot control.
even after i've driven our AllTrac Celica for a while, and have gotten comfortable with the feel of a turbo, i am still not a fan of the whole 'turbo' thing.
(time to rant!)
one thing i've noticed from most people that increase the power of their motors, they dont put the slightest thought to the brakes.
i recall when i got my mr2, that the first upgrade i did was to the tires (ie. wider and stickier tires), then right to upgrading the brakes. suspension followed in very short order... and, its been a slow process ever since.
this is one reason why i've focussed so much time and effort into upgrading my brakes. hence, the 2 sets of dual piston calipers that are in the front room. i'm going to mount a set on the front and rear, then make my parking brake hydraulic. it should all be quite interesting. i even have the brake master cylinder from a non-abs 91 turbo mr2.
this brake master cylinder has a larger opening for fluid to pass thru. this means i have to press less on the brake pedal to attain the same amount of force exerted on the brakes. and with the fact that there are 2 pistons, it means greater clamping force, which turns into later braking with less effort on my part. also, with this upgrade, i'm also moving over to vented discs front and rear, which means i can balance the braking potential of front vs rear more to what i feel comfortable with.
this is attained thru the purchase and installation of a brake bias adjuster, with a manual dial adjuster mounted in the cabin near the center console. this allows me to be able to adjust the balance of the brakes while driving too!
along the way, i'm going to purchase a TRD LSD for my mr2. running with an open differential really isnt comfortable. and lord knows that i'm going to need it once this brake setup is complete.
in order to properly handle the power i'm planning on producing in my mr2, i'm also going to fit some 225 width tires on the rear.
and now... the area that i know virtually nothing about... transmissions! what sort of gear ratios/acceleration do i want? one would think (myself at that) that Toyota has chosen specific gear ratios for specific reasons. my guess is that the ratios match the power output of the motor its been mated to, to create a comfortable and drivable setup. i can only hope that 1st, 2nd and 3rd have the same aggressive acceleration that my mr2 has currently.
so, in a nutshell, there is the majority of the plans for my mr2 and all the little thoughts bouncing around in my head...
(time to rant!)
