where's the oil leak? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2009, 09:15 PM   #1 (permalink)
View jesse0880's Photo Gallery
There is oil leaking from the bottom corner (pulley side) of my oil pan. I thought is was because i used a cork gasket but the leak drips to oil I think. I'm scared its the main seal cause i can see oil on the alternator bracket and the bottom timing cover. Could it be anything else? its a 91t and I just rebuilt this motor and I used all new gaskets and washers...
jesse0880 is offline   Reply With Quote
Old 02-09-2009, 02:53 AM   #2 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
I don't know much about cork gaskets but I do work under cars everyday. All sorts of kinds of cars. I've seen cars that are still pretty new with pan gaskets starting to go. Quite sad really.
Do you have any pictures of the leaky area? that would probably help
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 02-09-2009, 11:51 AM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I have been using a cork gasket on my oil pan for the past year. It didn't leak.
Possibilities for a leak in that area are:
Front oil seal, oil pump,valve cover gasket and intake cam seal.
Since the alt. bracket is above the oil pan , I wouldn't think it's the oil pan gasket.But it's still possible
If it's getting on the alt. bracket, there must be some pressure behind it.
If there's oil on the top part of the bracket, then I would be looking at the valve cover or intake cam seal.
If it's the lower part of the alt . bracket- the oil pump or front main seal.
Of course, the oil could be dripping down from the top. Clean it up and try to pin point the area.
The Jedi Speeder at CarDomain
Old 02-10-2009, 07:07 PM   #4 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Valve cover or cam seal. Probably the valve cover.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
