Signal Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2009, 02:21 PM   #1 (permalink)
Wheelless wonder
View EMareTWO's Photo Gallery
Signal Problem
Hey all,
I have a 1992 Toyota MR2 N/A and just changed out my dash light bulbs because they died out. I used normal oem bulbs to replace them.
What happens now is that the turn signals on the steering column wont turn or "click" when you pull the signal arm down. The green arrows do not turn on at all as well.
Keep in mind that I did connect all connectors besides the odometer wire since it is very difficult to disconnect and connect them. Can anybody offer any advice?...Thank you kindly.
EMareTWO is offline   Reply With Quote
Old 02-11-2009, 05:35 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Sounds like something didn't get connected back correctly or something is grounded where it shouldn't be. Did you disconnect the battery before starting the bulb replacement? If 2 things touched that shouldn't have, could've shorted out the flasher or maybe a fuse.
The Jedi Speeder at CarDomain
